Theme: Residential Interior Cinematic Walkthrough
Artist: Clinton Dhasan
Graphics Card: NIVIDIA GeForce RTX 3090 Ti
Workflow: Modeled in Revit, rendered in D5 Render 2.9, with post-processing in Premiere Pro
Model source: Original
Description of the work:
This cinematic walkthrough shows off a cozy residential interior I made with D5 Render 2.9. I focused on making the lighting, textures, and overall vibe feel as real as possible, so it’s like stepping right into the space. Would love to hear what you all think—any feedback is welcome!
very good job. im surprise why video is not in 16:9 ratio. i cant say more after all its artist liberty. but good work. keep it up.
Thanks a lot! Yeah, I know the 16:9 ratio is the standard, but I just wanted to try something a little different. I totally get it, though—next time I might go with the classic format. Appreciate the support!
great work. But your animation is jerky. Did you try to convert your mp4 file before sending it to Youtube?
Thanks for the feedback! I noticed the jerky motion too, might be due to the file conversion before uploading. I didn’t use any specific settings for compression, so maybe that’s where it went off. I’ll definitely try converting it differently next time to smooth things out. Appreciate the tip!
I use 60 fps and then open it in premiere pro, and export
I used 30 fps at 4K and it played smoothly. I even uploaded it to Instagram without any lag, but on YouTube, it’s lagging for some reason. Not sure what’s causing it there!
