Hello developers and forum members.
I’m new user so probably some of my wishes were already mentioned, some perhaps even solved.
- we definitely need PDF manual with all capabilities, tips and tricks. You tube is good but serious manual is a must.
- I would like to see option for selecting single faces or triangles, maybe some magic wand, when assigning the material. Going back and forth between modeling (Archicad) and rendering could be annoying and time consuming.
- vegetation seeding. Could it be linked to material. I’ve tried grass seeding and there was grass all over tiled floor even if the slab was higher then terrain.
- layering, if anyhow possible to have layers from original model, turn on/off option and material choice.
That much after only several hours of tryout.
Best regards to everyone.
Miro
