It would be amazing if effects such as watercolour effect, pen sketch effect and so on effects can be integrated in Realtime rendering. rather than a post processing/post AI feature. or even if this feature could be integrated into video renders too.
Thank you for your feedback, @Ameez . Could you share a bit more about:
Is it because the AI post-processing style differs from the original building massing, or is there another reason to add this kind of stylized content in the post-processing panel?
Also, can I ask what types of scenes you usually work on and how often you need stylized render results?
Thank you again for your input.
Not really, I did notice the few inaccuracies during AI post-processing. but for concept stage those were negligible. I m sure the AI post-process will be improved in the future.
What I really meant was something similar to what Lumion has, where styles can be applied before rendering. Therefore, the styles can be rendered for videos too, vs an AI post feature which is limited to still images if I m not mistaken and needs a base render. refer to the video link below for reference.
ARTISTIC RENDERING in Lumion with Effects
and currently I mostly work on Architectural building exterior and interior rendering with immediate context rather than large urban projects. and for concept design the stylized looks such as watercolor or pen sketch AI post process is very useful. we tend to render realistic visual at more design developed stages. So for all projects at concept stage we use a more conceptual style. Even before the introduction of this feature in D5 2.9 we used to render realistic renders with multiple line sketch layers and combine to make it more conceptual in photoshop. So we use it very frequently.
Ok, understood
. Thank you Ameez,
I will discuss this requirement with our product management team.
