I was looking for an answer to the same question, but this doesn’t help if you already had a lot of work on a shot with camera movements and environment.
Could you add an function to copy an entire shot to a different clip, please
Thanks for your advice. I recommend you could write your need in the idea& request channel.
@LunaLang - That puts a lot of extra work on the customer. You appear to be the moderator of the forum, so I believe you can move this thread or convert it into “ideas and requests”. That way all the supporting information for the idea goes with it. This way you can reduce the level of redundant information.
Agree - this work for very simple camera movements. For more complex clips it become a bit of an hassel.
It’s quite frustrating every time @LunaLang or someone from D5 says, go ahead and post it in Idea & Request. It’s been already posted. D5 team should convert the tread to Idea & Request as @jtubb suggested.
Thanks for your advice. ![]()
