Unified Material Manager: Multi-Select & Bulk Parameter Editing
Managing a complex scene in D5 Render can be a dream until you hit the “Google Earth” or “Large Site” wall. Having to click through hundreds of individual mesh tiles just to tweak a single roughness value isn’t just tedious; it’s a workflow killer.
​Feature Request: Bulk Material Editing & Dedicated Material Manager
​The Problem: Micro-Management of Large-Scale Models ​Currently, D5 Render relies heavily on a “select in viewport” workflow. While intuitive for small scenes, it becomes highly inefficient when dealing with:
​Imported Photogrammetry/Google Earth Data: These models often arrive as hundreds of individual tiles, each assigned a unique material name despite needing identical parameter adjustments.
​Complex BIM Imports: Large architectural projects can have hundreds of glass or metal variants that require global updates to specularity, reflection, or mapping.
​Manually selecting and editing these one by one is prone to error and consumes hours of production time.
​The Proposed Solution: Unified Material Editor Window
​We need a dedicated, non-modal Material Manager Window (similar to the classic surface editor in Lightwave 3D):
images/SurfaceEditor-multiple.gif
​Key Features:
​* List View: A vertical list of every material currently in the project.
  • ​Multi-Select Support: The ability to Ctrl+Click or Shift+Click multiple materials in the list.
  • ​Batch Parameter Overrides: When multiple materials are selected, the inspector panel on the right should display shared parameters (Roughness, Specularity, Metallic, etc.). Changing a value here should apply it to all selected materials instantly.
  • ​Search & Filter: A search bar to quickly find materials by name (e.g., searching “Tile_0” to grab all photogrammetry chunks).
​Workflow Example: The “Google Earth” Scenario
  1. User imports 200 tiles of a city model.
  2. User opens the Material Manager.
  3. User searches “Tile,” selects all 200 materials.
  4. User adjusts the Roughness slider to 0.8 and Specularity to 0.2.
    Result: All 200 materials update simultaneously, a task that previously took 30 minutes now takes 30 seconds.
Why This Benefits D5 Render
  • ​Scalability: Positions D5 as a more viable tool for massive urban planning and master-planning projects.
  • User Retention: Reduces “friction” and frustration for power users and professionals coming from traditional DCC (Digital Content Creation) software.
  • Organization: Provides a bird’s-eye view of project assets without needing to hunt for them in the 3D viewport.
No comments? Really?
