i have already installed D5 render for REvit now i wanted to install it for sketchup in the same PC but its telling that the software can’t be RUN on my PC,
Is it not Possible to use converter with different softwares?
HI
It seems strange to me, because on my laptop I use Archicad and Sketchup, they both have the Synchronizer that is the Plugin to connect with D5 and they work perfectly, perhaps if you notice there are two for sketchup try with the other.
well i Tried that and i can install live sync Software but the converter is not installing
You have to ask Tim D5, does it depend on something bothering him, or is there something blocking the installation. They will surely answer you and ask you some more precise questions to understand where the problem comes from.
Good work
Could you tell me the version of your sketchup?
its sketchup 2023
Do you use any antivirus software or firewalls? You can temporarily disable them and then be present to try to install the plugin. Also, we have D5 2.6 and the new SU livesync plugin online today, you can try to update them.
