第一次的渲染,使用D5的功能都是正常
存檔重新開啟再做修改,飛行功能就會無法使用
D5會連同sketch up一同崩潰
有重新安裝D5程式,但同樣的狀況還是會發生,就需要刪掉原D5檔案重新設定
請問可以從哪裡檢查,是否為程式的問題或電腦配備不足??
第一次的渲染,使用D5的功能都是正常
D5會連同sketch up一同崩潰
Hi there, sorry for the inconvenience. Does this problem persist in other project files, or is it file-specific? What SketchUp version are you using? Issues that are evident even with other files are most likely hardware issues, but it still depends on the case. Can you also send the following information? Please refer to these images.
Note: Please run the D5 and SketchUp files while opening the task manager.
Additionally, I suggest reinstalling your drivers cleanly to keep them up-to-date and avoid future issues and complications in D5 Render.
Let me know if it helps solve the issue. Thank you~
Hi, thank you for updating us on how you were able to fix the issue. Your statistics seem to be fine except for the temperature, which is somehow relatively high, but I think that can be controlled through other external factors
Anyway, regarding the new issue you are encountering, you might want to check if you have renamed or relocated the SketchUp file before syncing. Any relocation or renaming of files that were synced would result in such an error; you can rename it again to the old file name or put it back in the previous file directory.
You might also want to check your file’s version history
Also, is there a prompt window before opening the file similar to this image?
Thank you~
反應的問題,重新安裝後,目前有獲得了改善
非常感謝您的協助,謝謝
Thank you for your update~
