We would liked to see this mode of installation (MSI package) include for managed installation by Administrator. This will helps us alot to reach out to more staff.
Hi @LW2024 , thanks a lot for the suggestion.
BTW, you can try the CMD installation option for the installer file, which is convenient for IT administrators to automate deployment and configuration through scripts, as detailed here.
If you want to install D5 on multiple computers simultaneously, you will also need to use a batch IT tool that can execute command lines on many computers at the same time.
I think this should serve as a temporary solution in place of the MSI package.
