Tip for removing plants under geometry
A common scenario happens when you update a model and you have planting underneath the ground level due to the changes in the landscape or floor levels etc.
Previously I would go under the surface to try delete the brushed on planting but I have just discovered something very helpful.
If you are moving forwards while you delete your brush will go through geometry and delete objects even if they are hidden under a few layers of geometry.
