Please could you add a striped lawn grass to your current 6 template grass styles.
hi @3DG thanks for the suggestions. You can try applying the grass material template and then replacing the default base color map with your desired striped texture. After that, adjust the ‘Blend amount’ parameter and ‘base color’ to achieve the desired effect.
