Sync Model replacement dialogue box needs resize option to see full, long file names
When syncing updated models and the “replace” dialogue box appears, long file names appear cut, and cannot resize the window or file name column to see the whole name.
This is a big issue for long BIM file names, please add a window or file name column resize, or a mouse hover “show full name” option… TYSM in advance.
In general, the whole UI should be resizable, in our company we use a standardised naming convention, which is also a bit longer than usual.
thank you so much for the reply, that is exactly the point, our naming convention is quite long as well. i don´t think a UI resize capability should be too difficult to add…
