Does D5 allow to do solar studies based on location of the project? I’ve just installed D5 but now waiting on the new graphics card to arrive before starting to use it.
From various tutorial videos I can see that the sun can be manipulated quite easily but I need the ability to render accurate sun studies based on the projects geo location.
If this isn’t available at this time, are there plans to include this feature. It is essential from an architects point of view.
i just entered my correct geolocation and the sun shadows are not according to the location. I don’t understand why I would need to enter a geolocation if it does not give the right shadows.
The issue is that days are not much longer in summer. When I set the date to June 21, in D5 the sun goes down at 7PM while in reality this is 10PM. Orientation of the sun is fine, it is just that the time of dusk and dawn are wrong.
Hi mate, the situation should be considered when developing this function. If there’s bug when you use D5 Render, can you please share with us more details?
If your project is in the Southern Hemisphere, the latitude and longitude must be negative, for example Buenos Airess: Latitude and longitude coordinates are: -34.603722, -58.381592.
North orientation at 0º or its corresponding variation
Hi, I am also noticed this when I am using D5 render 2.11. The sun position is wrong compared in my BIM software (Archicad) initially I thought it will copy the same position its displaying but no. Then I manually keyed in the long and lat and north offset still showing a lot of difference… is this a bug or still not resolved until now? Thanks.
