Dear team.
I hope you can make more updates on the following 3 aspects:
- the freedom to define the size of the rendering frame
- update the line mode for rendering so that the line width will not be messy when complex details are rendered
- the synch mode now is single direction, which means rendering in D5 can present what can be seen in Rhino. But, it is inconvenient after minor adjustment is made in D5 and the final result can’t be fed back to rhino model space.
I think you will be of a great help if these points can be updated!
Thank you!
