We have stage light but lack of light source according to object - beam model. Then the stage lighting will look more realistic. Hopefully one day soon we will have a beam model with stage light
OK, no problem, welcome to show us some screenshots of stage lights you use as reference.
We have beam model with animation and stage light.
We have laser light.
LED screen light does not affect the environment
White light of emissive, not video light
Ok, thank you!
I have looked in the library of “Moving head beam light” , but the beam only points in one direction, when I need to change the direction of the light, the direction of the beam is not correct. How can I control the direction of the “Moving head beam light”?
Hi mate, sorry that it is not supported to rotate that “head” directly, we may modify the model and support that in future.
I hope it will be modify soon. Thank you!
Hello !
I just started using D5 Render and I wanted to create these kind of beam model with animation and stage light. Is there tutorials available for this please ?
I appreciate the lighting capabilities in D5. It would be great if the D5 team could focus on the KTV interior design field. Many people are looking forward to seeing dynamic lighting effects with moving heads and lasers… It’s a pity that after such a long time, we haven’t seen any significant improvements in stage lighting
Hi! I’m doing stage design too and it’s quite frustrating to not be able to have this kind of lights in the model. I really hope you’re adding at least some accurate beam light since there’s the model but the ies doesn’t allow to have a longer attenuation radius. The lights in the assets are good for small stages like little theaters, and not big festivals. Thanks for hearing our suggestions!
