I think it would be nice if a brush record has a single ID color instead of every object in the brush having a different color.
This would help a lot in post-production, for example Photoshop, where you can select by color .
Do you mean like this? Thank you for your advice!
Hi Bruce, see the image below. I mean when you want to select specific elements of your image (by using the magic wand tool in PS e.g), and adjust them individually.
In the screenshot above, I would like to select the green roofs of the buildings, so that I can change the color/contrast a little. But since every object in this scatter brush has its own color, it’s nearly impossible to make a clean selection. Same for the plants a little higher on the image. I like to make individual adjustments to these different elements in my images.
I don’t know if this is an unusual approach or not, but it certainly helps to have more control in post!
Cheers
Got it, Thank you for your details!
Definitly need this! thanks ![]()
