Hello the team, I have a suggestion to improve the use of the clipping plane.
Is it possible to add a shortcut to able or enable a set clipping plane. I often use the clipping plane to prepare a scene but as soon as I want to work on the model I have to set the clipping plane to 0 to be able to work correctly. Same thing for the two point view perspective which is from now locked when you move the camera…This change the way I move in my model…
What do you think about that proposition?
THANK YOU
Thanks for your suggestion, I have shared this suggestion with my team.
For the two point perspective view and perspective view to be locked when moving, this is a new feature of 2.4, you can use the shortcut P and F8 to switch
ok thank you , however why did you locked the 2 point view? Because before it behaved like in sketchup. Is it for animation?
When you switch from a set scene to a working environment, it is quiet strange and very deformed even if you have a shortcut to enable it. I think I prefered the unlocked behaviour from before…
Sorry
