Please implement the ability to Save and Load “scene parameters” to file. Useful if you want to reuse your scene settings(environment, hdri, effects, etc) into a newly created D5 file. So you have a consistent mood on your renders each time you create a new scene, just load your saved parameters from file.
Right now D5 has a copy and paste parameter. Can be implemented also on right-click menus of each scene (“Save parameters to file”, “Load parameters from file”)
Please add the camera position and movement in the saved parameters.
It would be handy to render several variations of the same scene with different backgrounds fotr instance.
Hi mate, we will have the camera position in the 2.5 version. Please be patient with the update. Thank you for your advice, we will keep improving the “video” function in the next versions.
