Rhino7 crashes unexpectedly while working with D5
This issue never occurred before, but since the first half of last year, Rhino has been shutting down suddenly when I work with Rhino and D5 together. D5 continues to run normally, but Rhino closes abruptly, sometimes without even triggering autosave. I don’t think this is due to insufficient hardware specifications. I would appreciate it if you could let me know what might be causing this problem.
Same problem with Rhino 8 and plugin D5_Live_Sync_Rhino_usa_1.1.3.0016.
Hi @studiotetris @cyh21534
Sorry for the inconvenience. Please try the version our colleague shared in this thread. Let me know if the issue persists. Thanks in advance
Tested yesterday afternoon and this morning after searching the forums but same exact problem…I need an even older plugin.
https://usa-plugin.d5cdn.com/installer/Rhino_LiveSync/8b2288b85ecd4fd2a8a39c0bd26d8f12/D5_Live_Sync_Rhino_usa_1.1.0.0002.exe
Thanks, I have tried these days for many hours and the plugin works perfectly. Thank you!
Hello, I am experiencing the same problem with the latest version of rhino 7, the latest D5 livesync plugin, and the latest version of D5. Rhino initializes ok, but then the livesync plugin causes opening up a workspace to crash. The older version of the livesync does work… but its rendered useless if I can’t actually use the livesync function due to D5 being up-to-date.
