Help! I’m trying to render a project from Revit, but none of my light fixtures are populating the model in D5. Happy to add the lighting part in d5, but I need to see the fixtures themselves. Is this a setting issue?
It worked previously, but now they won’t pull. They are in my model and not in a linked model FYI.
Could you please share a screenshot or a short screen recording of what you’re seeing on your end? That will help us understand the issue better.
Also, may I know if you’re directly importing from Revit to D5, or using the LiveSync plugin? If you’re using LiveSync, please let me know which plugin version you have installed, as well as the D5 client version you’re currently on. Thanks!
