I know this is early, but when is D5’s plug-in for REVIT 2026 expected to be released?
Thanks
Thanks
I also need d5 Revit 2026 plugin ! Please help D5 TEAM, remeber that there is no reverse file compatibility in REVIT. So if I start working in 2026 version, I wont be able to SYNC to D5
I need D5 plugin for Revit 2026 ver too! Make it ASAP, please.
please, this is priority
Any update on when we can expect this update for 2026?
Revit 2026 plugin ???
Same! need some update of this
Ho assolutamente bisogno dell’aggiornamento. Grazie
Is there any update on this as I need th e2026 version a.s.a.p.
Io ho risolto copiando la cartella d5 converter e d5 converter.addin da Revit2025 a Revit2026. Ora funziona
Thank you all for your patience and continued support!
We understand the demand for Revit 2026 compatibility and are actively working on it.
There is currently a test version available for internal testing in the D5 Sync - Revit section of our Discord channel.
Feel free to join Discord to download and try it out!
Can you reshare the link as it is unavailable rn? We need the synch file asap’ we would be very happy if you are interested.
We need Revit 2026 too.
Yes, please. I need this!
I there an update on this? I am eager to try D5, but our office is on Revit 2026. Twinmotion updated their compatibility within a couple weeks of Revit 2026 launch. Is it normal for D5 to take this long to update?
can i also please get the Revit 2026 plug in.
thank you
hi!
is any advance on this? ![]()
Any update or estimate of when the revit 2026 plugin will be available?
Hello! Can you tell when it is planning to release Revit 2026 Plug-in?
D5 Factory: I respectfully suggest that if your customers can’t rely on timely plug-in updates, you will lose your market.
