Render Multiple Variations from the Same Scene and Camera
The presentation feature for multiple variations is really useful for showing different design options or facade concepts.
But would it be possible to render these variations directly? It would be very helpful to create high-quality renders of several variants from the same camera view and with the same render settings, without having to duplicate scenes manually.
Right now, the workflow becomes difficult when adding new variants. If I already have several scenes set up, every new variant appears in those existing scenes, so I have to go through all of them again and manually hide the new variant where it should not be visible. Then, for each design option, I need to create separate scenes with the same camera position and the same render preset.
The important part is that each variant needs its own renderable scene or render state. It is not enough to constantly update the same scene by manually hiding and showing different variants. For real project workflows, we often need to keep all variants organized and render them later from the same views.
It would be great to have a feature that allows variations to be added directly to the render queue, using the same camera position and render preset. For example, rendering 2, 6, or more design variants from the same views, and leaving everything in the night render queue for 40+ images.
Maybe this could be added as an option inside the Presentation tool, or as a similar workflow for Scenes. Also, duplicating scene groups would be a very useful improvement.
