Release notes | D5 LiveSync for Vectorworks
Ver: 1.3.0.0008
Release date: 2026 09 10
New
  • Added support for Vectorworks 2027.
  • Added support for OpenPBR materials.
Fixes
  • Fixed an issue where Vectorworks could crash when disconnecting LiveSync for files containing textures in VW 2026.
  • Fixed an issue where the model remained in Clay Mode after reconnecting LiveSync.
  • Adjusted some UI text.
Ver: 1.2.0.0012
Release date: 20251105
New
  1. Supports Vectorworks 2026
Ver: 1.1.1.0035
Release date: 20250626
Fixes and Improvements
  1. Occasional plugin crashes on certain Windows 11 systems
  2. Sync crashes caused by mismatched UV size and point data
  3. Plugin crashes caused by empty UV data in models
  4. Incorrect normal direction synchronization for some mirrored objects
  5. Optimized sync logic for scenes without renderable 3D data to avoid freezing
  6. Improved plugin handling and popup prompts during special operations in D5 (e.g., model deletion, D5 Render upgrade)
Ver: 1.1.0.0016
Release date: 20240912
New
  1. Supports Vectorworks 2025
Fixes
  1. Abnormal sync issues between light name and Custom Light (IES)
  2. Abnormal material sync issues between mirrored Object and Symbol
  3. Incorrect face normal synchronization in some models
Ver: 1.0.0.0034
Release date: 20240703
New
  1. Supports Vectorworks 2024, D5 Render 2.7 and later versions
  2. Supports LiveSync of models to D5
  3. Supports LiveSync of Renderworks Texture to D5
  4. Supports sync of lights to D5
  5. Supports LiveSync of viewports between Vectorworks and D5
  6. Supports ‘Active Only’ for Class/Layer
Known Issue
  1. Only supports Perspective view
  2. Currently, lights only support Point Light, Spot Light, and Custom Light (IES Light).
