Relaod model in Phasing Animation
Good morning everyone. I would like to ask the D5 team a question about Phasing Animation:
  1. I successfully exported the .d5a model with groups from max.
  2. I have successfully created the animation with Phasing effects.
    If I needed to make a change to the model in max, there is no reaload function in D5. I can’t synchronize. Can you help me? Thank you.
Hi there. Unfortunately, we have yet to add the reload button for the .d5a import to D5 Render. If there are any changes, you may want to reimport again or right-click the object and then click “Replace to Local.” This method will not retain the materials and the parameters you have placed earlier; hence, it would also be beneficial to add the materials you have used in your Local Library to retain its parameters and easy navigation.
We will develop this feature further in subsequent releases to ensure a smoother workflow. Thank you.
