Refresh rate
the proart with 60 hz refresh rate is ok for d5 render?
Hi there, D5 Render does have a maximum 60hz refresh rate given that the files is not too heavy. I think the 60hz refresh rate is enough to run D5 in your computer as long as the system info reached D5’s minimum requierment. Thank you
