Why not insert values into the cameras and respective scenes as is the case in Cinema 4D, and you can later change these same values. Also a fantastic upgrade was to record the values of the different HDRS in the scenes and values of cameras on the same document. Shift night, day, and keep values of camera cuts. Thank you for your attention.
Thank you for your advice, it’s forwarded to the Team.
This would be a huge upgrade. Thanks Bruce for the last helps. I love working in D5 Render.
