Questions about 5D Render
  1. How to insert a scene or an imported 3D model in my photo?
  2. How to replace the material or texture on only one side (face) of the object?
  3. How to edit the material on the object that is behind the glass using fast keys?
  4. How to create a reference file, then to quickly and automatically pull textures and materials, arrange objects, sun, background from a previous project?
  5. How to make the material invisible, or so that it does not accept the shadows, or so that it does not discard the shadows?
  6. How to make an alpha channel in color on a texture, and not on an additional texture-mask?
  7. There is not enough an additional window with a 2D plan and with 2D -based projections of the scene -for accurate positioning of objects, light sources, cameras.
  8. Not enough palette of RAL colors.
  9. There is not enough inclusion of the plane of the earth or relief (mountains) to the horizon.
  10. There is not enough Russian language in the program.
  11. There is not enough ghost material (it becomes invisible material, but accepts shadows)-so that I can insert the objects in the photo, and so that they cast the shadows in the photo.
  12. There are not enough 3D grass with the inclusion of rarely placed dandelions and wildflowers.
  13. There is not enough the possibility of dragging 3D models of the SKP format from the conductor to the program window (without importing them).
  14. There is not enough button for installing the camera perpendicular to the selected plane.
  15. How to visualize not the entire window of the program, but only a window fragment allocated to the frame?
  16. When importing a 3D model, there is no way to smooth out the surface of the material on the model.
  1. The imported model does not have a list of all materials. When I edit the materials, you can’t see which Ortededactics and which have not yet edited. It is also possible to simultaneously select in this list and edit several materials (in some models there are many of the same type of materials).
  2. There is no way to divide one material into several different materials.
  3. Add the moon and stars in the evening and night sky.
  4. For 3D objects, create a function of logical subtraction (for inserting built-in fireplaces, spots, niches, etc.).
  5. Make sorting by the name of local models and materials, as well as the ability to add subcategory (example, how is the online library).
  6. Make it possible to turn off the materials (make them invisible) so that other materials located behind them can be edited.
  7. We need automatic optimization of imported models based on artificial intelligence - relief of the size of the model (less than 100 MB) and smoothing surfaces with the possibility of further manual editing.
  8. We need the ability to turn on or disconnect the sound signal at the end of visualization.
  1. We need the ability to place any texture without its repetition or replication (for example, add one logo on top of another texture or material, add a stain, smile, dirt, etc.).
  2. You can make an additional request when updating the species. Very often, when choosing the previous species, we miss a little and click the renewal of the camera, and then the species point is rewritten and the previously configured look is lost (two identical species points appear).
