Hello D5 team,
If it were possible to point catch in D5, that would be a great help.
For example, when precisely placing objects or partial scenes.
I often export parts of my project and then put them together in D5.
This has the advantage that I don’t always have to swap the whole scene when making changes.
In addition, when creating grass areas, these are then assigned to the partial areas.
which makes it easier to work with different grass areas.
Bye
Andreas
its already there if im not wrong. condition ur base object origin will be main . later what objects u will import will follow base origin. u have to select sync coordinates imported object. please check it works or not.
Hello visualplus,
thanks for the tip.
I’ll give it a try and get back to you.
Until then…
Live long and prosper.
Andreas
… I tried it out… worked great…very good.
Nevertheless, I think a point catch function would be desirable.
Dies würde auch das platzieren von Objekten erleichtern.
Bye
Andreas
happy to hear it worked for you.
u mean point catch function aka node base placement.
