Hello D5 team, it would speed up workflow if we could have the option to align model to other surface instead of having to rotate the object to match the angle of the surface every single time, it is actually surprising this isn’t implemented in d5 yet. you have this implemented with trees aligning with terrain using its normal, this need to be also implemented for any object not only on floors, but on walls as well.
thank you
