A picture image is split in Rhino, but D5 is not showing it correctly.
Hello, have you added mapping axes to your model? Are you currently using the sync plugin to sync to D5, or have you imported the model directly?
what do you mean by mapping axes?
Using sync plugin
Sorry, I just mean texture mapping toolbar.
It was imported as picture and I split it. Not sure why and how mapping helps, but could you eleborate?
This function helps you to resize the texture to the right size so that the texture is displayed at the right scale.
The question was why D5 is ignoring what is shown in Rhino. It should match.
Hi! Is it convenient for you to send us your rhino model? We will check it.
You can share a link here or send your model to our email. (support@d5techs.com, please describe the problem and attach the link of this post to your mail)
Strange. When tried in a new file, it worked fine – trimmed picture images shows up as expected. Last time, D5 showed the whole picture instead of the trimmed image from Rhino.
Glad to hear you have solved the problem. I think you can still send us your rhino file if possible and we’ll try to check it.
