OBJECT LIST: Sort objects by alphabetical order, batch rename
Please add a way of sorting objects in listing (ascending, descending, by file size, by asset type, etc.)
And a batch rename of identical objects. Like, I select several identical assets in the list, and rename them all in one go (if they are instances of the same objects of course).
Perhaps add a command in the right click menu: select instances
It would be handy to select all the instances of a same object and then change their layer, or reload them, or delete them.
Maybe also add certain tags to objects. like the color and material, that way I can easily find purple plants or leather of fabric furniture for example.
Thank you for your good advice, I will share it with D5 team.
Good suggestions, thank you!
Is it possible some way of sort online and local library models alphabetically?
