New version of Rhino Livesync crashes instantly
This morning upon launching the D5 launching I was prompted to upgrade to the newest version. I did and when I wanted to connect my existing file to D5 (same rhino and D( files I had been using last week) rhino instantly crashed .
I updated D5 and rhino to their latest versions and the crash still happened . I tried to sync an empty rhino file (with just a cube in it) with the same D5 file and it worked . So it seems the problem is with the existing rhino file or because it is too large . However the previous version of livesync didnĂąt have that problem .
Is there a way to download previous versions of livesync ? specifically the 1.1.0 version . All I have is the “D5_Live_Sync_Rhino_usa_latest” which only installs the latest version . I donùt have time to try and rework the file altogether .
Hi, Yeah I’m getting the same problem since I downloaded the latest livesync earlier today. Any fix would be grateful. Thanks!
Hi @eli @seb.eble
I apologize for the inconvenience. Please send me the following screenshots:
If you can also generate a log file and video recording showing the issue on your end, that would also be very helpful.
I await for your reply. Thank you.
Hi Clov,
I’m experiencing a crash issue with the Rhino Live Sync feature in D5 Render.
D5 Render crashes whenever I use Live Sync mode and make real-time changes to my Rhino model. The only workaround I’ve found is to disable Live Sync and manually use “Sync Once” each time I need to update the model.
Version Information: Please see the attached screenshot for version details.
Screenshot 2025-10-28 092446
Link for the log File: https://drive.google.com/file/d/1jTOoSmBAEHzG_HmCMM8ZY18h1OYgTqDE/view?usp=sharing
Could you please look into this issue? Let me know if you need any additional information.
Thank you
Hi @christined
Thank you~!
I would just like to clarify if this issue occurs with all of your files, regardless of whether it being too heavy or too small? Does it also occur in completely empty files?
May we request the following also:
  • The Rhino File that is causing the issue.
  • A video recording on your end (just in case we cant replicate it)
Hi @Clov
Thanks for the reply, I downloaded the newer livesync, version 1.1.2.0005, earlier this morning, and so far everything has been working i.e. no crashing.
Thank you,
Eli
Hi @eli
Got it, thanks for your update. Please let me know if you encounter it again.
Hi Clov, I am having the same issue that Eli was having, but I have the latest version of Live Sync. As soon as I start the Live Sync from Rhino 8, Rhino crashes. It does not do it all the time, but for some reason it keeps on doing it to me right now. I will attach the version I am using.
Hi @dkraus2021
  • Does this window also appear upon opening Rhino?
  • Have you tried going back to the previous plug-in if the issue persists?
Before trying to go back to the previous version, I may need to collect the following:
Please send them to me privately.
I am also getting the error after downloading the latest plugin. Rhino crashes Instantly. Can anyone share the previous version installer
Hey, I will send you a previous version (at least it is a previous one for me), and try that. I guess the current is 1.1.0.0005, but I have a 1.1.0.0002 download in my files. It seems to work for me so far. It says “latest version”, but that’s just from when it was the actual latest. Hope this helps
D5_Live_Sync_Rhino_usa_latest.exe
Yes thanks. 1.1.0.0002 is working, the next version is having some issue.
3 posts were merged into an existing topic: [Hot Issue] Rhino D5 LiveSync plugin (1.1.2.0005) crashes
Hi @gceci002
Sorry for the inconvenience. Please collect your dump files from version 0009, upload the zipped folder to WeTransfer and send me the link privately. You can find the guide in my post above. Thank you. :blush:
Kindly refer to: [Hot Issue] Rhino D5 LiveSync plugin (1.1.2.0005) crashes - Workflow - D5 RENDER FORUM
