Moving Objects Independently in D5 Render After Scene Importation
Hello, have you planned to import a scene and then be able to move each object independently, as I saw that on Twinmotion we can do it, this allows total freedom of staging in D5 Render, Because there we we have to go through the original 3D software to redo the placement of an object in a scene, this is something to think about for a future version by your technical team, I can tell you that you will bring a lot more in productivity. THANKS
Importing a scene while keeping the hierarchy of object is a must, and should be present as an option during import in D5. It will allow a much greater flexibility once in D5.
in the latest version of live sync for sketchup there is this tool for exporting a model while keeping the hierarchy. i discovered it by chance. It can replace the ‘keep hierarchy’ option of Twinmotion in some cases, but I can’t find any documentation on this tool.
livesync
I use Revit and since objects are not individual, I will never be able to add a pivot animation to a door for example. (Without timely workarounds.)
