Looks great!
I would add background elements / shrubs / trees / fence so that the white sky isn’t visible through the bottom of trees and also set the focal length to 24mm at least, 28-35mm ideally (closest to human eye). Some join lines and water stains where the building and pergola meet, rather than smooth transition would also look good.
In addition to DSB comment, I’ll change the bark texture on the right side tree, to get more bump and realism. even the leaf look very 3Dish. So maybe try to find a better tree for the foreground.
Add a bit more roughness to the stucco, to remove to glossy effect on the left.
The sun lounger looks to perfect and to geometric, try to tic the round corner option on the texture.
And last, the fallen leaves are a bit floating on the ground.
