Measurement Tape
Hi D5 Team
Need measure tape… just to check some dimensions, like how wide is some walk corridors,
or how far is object from street, between objects, squared meters and so on…
Would be nice to implement it in to rendering for clients…
Vote Up : https://d5render.featureupvote.com/suggestions/231592/measure-tape-dimensions-visible-in-render-if-possible
Really enjoy working with D5Render,
keep good work…
Antigravit
Thanks for the suggestion
we will take them into consideration
Hi D5 Team,
We require a measuring tape to accurately know the dimensions of various objects, with a particular focus on furniture.
Have a good work D5 Team!
ROS Architects
Architect Hatice Rumeysa Erdoğan
in fact I am obliged to place a cube and resize it in the scene to the desired dimensions to be able to place imported assets in the right place… it is tedious. It seems urgent to me to have this function. thank you also for your enormous work
Hi, is this tool still not available in version 3? I’m having a lot of trouble with a project today… and I need to measure distances.
5 years later, still no with v3
And that’s completely absurd: the fact that you can import a GLB or D5a format into D5 means you haven’t used live sync. Yet you need distance markers to place objects at the exact point corresponding to the scene in the modeling software.
