It would be nice if there was an option to round edges as a material property. This can considerably increase the level of realism without the need to enhance the geometry in Sketchup, which takes time and effort, makes the model heavier and often can’t be applied correctly in complex shapes.
When will this rounded corners and edges option be released?
I still use the lumion solely because of that. Please be quick because I want to convert to D5 Render!
Thank you Oliver! I also am looking soooo forward to round corners. I have used Vray more the last couple of months because I can do round corners . It is to destructive and time consuming to round all my geometry in projects especially when there is lots of design changes!
Me too please. I use Revit LT. It is particularly time consuming to create round corners on anything using Revit Lt or even Full Revit. $4000/yr software that still hasn’t introduced a simple fillet command. Yikes to Autodesk.
