I’ve noticed others having the same problem. Not only with Sketchup, but with other modeling apps. Doesn’t anyone have a solution yet? I’ve been using Sketchup with D5 for a couple of years now and never had this problem. Only with the latest update.
Hi rgentry23, i had the same issue - i found that texure maps in sketchup that have a long filename would cause this problem- when i changed the filename to a shorter version the texture would load in.
Let me know if this helps
