Material ID - Color Adjustment
Is there a way to adjust or configure the colors in the Material ID layer prior to exporting?
Hello, for now, we do not have this feature yet. Could you please tell me in what scenario you need to use this feature?
For example:
When editing the images in post-production, it would be great if you could give a single color to vegetation, so you edit the entire vegetation and not tree by tree or bush by bush. Also sometimes materials don’t necessarily need to have a single material ID, again, thinking about post-production of images.
Usually, when using a random color for the ID material, a situation occurs when different materials are assigned almost the same colors and it becomes very difficult to make the necessary selection in Photoshop. Or, for example, dense greenery on a flowerbed on the material map turns into noise. It would be cool to have the ability to adjust the mask colors manually.
I second this as well. This is a very much needed feature. I have tried even changing materials but cannot find a way to force material ID randomization or colour selection. Colours are too close to use in compositing causing leaks in keys and masking
