Material for each face
I want to set materials for each wall or surface like in Twinmotion, but when I use Archicad, the same material applies to everything. How can I change that?
change that in you modelsoftware (archicad) add a diffrent surfaces on each wall.
So, In D5, is that the only option? Unlike Twinmotion, which allows assigning different materials to each face.
Yes, currently synchronous by material type is the only option, but next year we will support more synchronization modes.
OK, I’m waiting fot the updating.
In order to change the material of each face you must put the surfaces in different layers in ArchiCAD, since D5 Render only recognizes the layers.
Hello, could you clarify further, for example, the layers and types you are using? We are preparing to offer more merging strategies.
Or could you provide a specific file so we can see the differences in sync? Thank you.
