Material Assignment
Hi, in Revit, certain wall, for example, generic walls (in this example Type A) are modelled in a few rooms. but the finishes varies. Is there any way to apply materials in D5 individually so it would not apply to all Type A wall material?
Otherwise, in revit, I would have to create different wall types, for different finishes.
Hi, you have to name the textures of the walls with different names, for example wall 1 texture 1 wall 2 texture 2 and by doing so with the other walls you then synchronize and you will have the result you wanted. If the walls have the same texture or color you have this problem that you can’t apply different textures, it doesn’t work like in Artlantis
