Lite Release Note
D5 Lite 1.8.0 for SketchUp
:date: 2026/10/09
Additions and Improvements
  1. Added support for SketchUp 2027.
  2. Added the Link Model feature, allowing you to import external .skp files as lightweight placeholders.
  3. Added custom proxy models. You can convert components into lightweight placeholders while displaying the full models in Lite, and restore the original components when needed.
  4. Improved tone mapping in Effect settings, with more flexible control over highlights, shadows, and midtones.
  5. Added a Fabric material template with Velvet and Silk effects, including controls for sheen and highlight shape.
  6. Added Highlight Stretch and Highlight Rotation settings to the Metal material template, with support for uploading tangent maps.
  7. Added a first-launch guide with options for adopting familiar keyboard shortcuts, including Enscape-style controls.
  8. Added a keyboard shortcut panel that you can drag out into a floating window to consult while working.
  9. Moved the FPS display to the title bar. You can toggle the FPS display and shortcut hints independently.
  10. The current field of view or movement speed is now displayed while adjusting it and automatically hidden when the adjustment ends.
  11. Field of view (FOV) adjustment now consistently uses Ctrl+Scroll.
  12. Added a context menu to material texture slots for importing, copying, pasting, and deleting textures, and opening the folder containing a texture.
  13. Added viewport frame rate limits of 30, 60, and 120 FPS, plus an unlimited option.
  14. Floating panels remain visible when switching between Lite and the modeling application. You can keep the main Lite window always on top independently.
Fixes
  1. Fixed an issue where deleting a scene in SketchUp did not remove the corresponding scene from the Lite Scene List.
  2. Fixed an issue where switching scenes or projection modes could cause Lite’s field of view and navigation mode to fall out of sync with SketchUp.
  3. Fixed an issue where child models could remain visible in D5 Render after hiding nested groups using SketchUp tags.
2026.9 Update
:date: 2026/09/17
General
“General” applies to SketchUp, Rhino, and Revit. Each section below covers platform-specific updates.
New
  1. Added a CLI, so you can adjust environment, lighting, materials, camera and post-processing in D5 Lite and render images from AI tools such as D5Arco, Codex and Claude.
    :warning: Note: Rhino and Revit do not include modeling-related MCP features.
  2. Added channel output, including SkyMask, MaterialID, Transparent and more, rendered alongside the main image.
  3. Rotating the view with the mouse no longer stops at the edge of the screen.
  4. Scene List thumbnails now show the full scene aspect ratio.
  5. Lite lowers its frame rate to free up GPU resources when both Lite and the modeling software are in the background.
SketchUp 1.7.0
Includes all General updates above, plus the following platform-specific updates.
New & Improvements
  1. Added a Reflection Visibility setting for lights, controlling how visible a light source is in reflections.
  2. The spotlight cone setting is now Beam Angle, shown as the full angle.
  3. Improved the spotlight model display so it no longer distorts at wider beam angles.
  4. Extended the material Normal range to -2 to 2, with manual input up to -5 to 5.
  5. Normal strength from SketchUp native PBR materials now syncs to Lite at its original value.
Rhino 1.2.0
Fixes
  1. Fixed an issue where Lite failed to launch when the system username contained special characters.
  2. Fixed abnormal window behavior when dragging the window between two displays with different DPI settings.
Revit 1.2.0
New & Improvements
Fixes
  1. Fixed a 90-degree offset in viewport sync when opening older saved files.
  2. Fixed an issue where Lite failed to launch when the system username contained special characters.
  3. Fixed abnormal window behavior when dragging the window between two displays with different DPI settings.
2026.9 Hotfix
2026/9/2
SketchUp 1.6.1
Fixes
  2. Fixed a save error caused by incorrect default material UV values.
  3. Fixed an occasional crash on startup in certain scenes.
  4. Fixed abnormal window behavior when dragging the window between two displays with different DPI settings.
2026.8 Update
2026/8/18
General
New & Improvements
  1. Added support for capturing the real-time render view, which you can copy to the clipboard or save locally.
  2. Added support for rendering panoramic images.
  3. Added the Sheer material template for a semi-transparent fabric look (SketchUp / Rhino).
  4. Added terrain grass culling-distance display.
  5. Improved consistency between terrain grass textures and mapped textures.
  6. You can now copy and paste Environment and Effect settings between scenes in the Scene List.
  7. Custom HDRIs now display the texture file name.
  8. Added Sun Radius and Sunlight Temperature settings to control shadow softness and sunlight warmth.
  9. Added a Radius setting for point lights, spotlights, and other light sources to soften light edges.
  10. Added an always-on-top button to the Lite window.
  11. The Resource List now displays asset names, making placed assets easier to find.
  12. Improved interface responsiveness.
  13. Improved texture loading for faster loading in large scenes.
  14. Improved camera transitions when switching scenes.
  15. Improved process stability.
Fixes
  1. Fixed a range of startup failures caused by process errors or conflicts.
  2. Fixed a crash when loading very high-resolution content.
  3. Fixed occasional ghosting in rendered output.
  4. Fixed an issue where mouse input could pass through panels in some cases.
  5. Fixed a startup crash on multi-GPU systems.
  6. Fixed other occasional crashes.
SketchUp 1.6.0
Includes all General updates above.
Fixes
  1. Fixed an issue that prevented saving layouts and keyboard shortcuts.
  2. Fixed an issue where environment sync did not work correctly.
  3. Fixed incorrect UV reading for materials without a base color texture.
  4. Fixed an issue where UV changes made inside a component were not synced to D5 Render.
Rhino 1.1.0
New & Improvements
  1. Added support for syncing the current HDRI or GEO environment to Lite.
  2. Added support for syncing scene data, including Environment and Effect settings, to D5 Render.
Fixes
  1. Fixed an issue where layer visibility was not synced correctly.
  2. Fixed display errors when switching scenes.
Revit 1.1.0
New & Improvements
  1. Added HDRI presets to the Environment panel for quickly switching built-in skies.
  2. You can now create, delete, and rename scenes in Lite, with two-way synchronization to Revit 3D views.
  3. Added support for syncing non-orthographic scene data, including Environment and Effect settings, to D5 Render.
  4. Added a compatibility option for the 90° orientation offset in models imported from earlier versions.
Fixes
  1. Fixed ghosting and flickering in orthographic views.
2026.6 Update
2026/7/2
General
New & Improvements
  1. Added HDRI presets to the Environment panel, including 5 high-quality skies: midday, sunny, light clouds, sunset glow, and pure white.
  2. Improved material opacity control for smoother and more natural semi-transparent transitions.
  3. Improved viewport navigation smoothness for more fluid camera movement.
  4. Optimized default brightness for newly created lights based on light type.
  5. Improved light intensity slider for finer adjustments in low-brightness ranges.
  6. Optimized light attenuation radius behavior.
  7. Enterprise edition now supports disabling AI features.
SketchUp 1.5.0
New & Improvements
  1. Improved light creation and editing workflow, with type-based creation logic, control-point dragging, and real-time preview support.
  2. Added batch editing support for multiple lights of the same type.
  3. Improved light visibility toggle behavior.
  4. Optimized Enscape scene import, with corrected mapping of light and material parameters.
  5. Improved accuracy of AI material template recognition.
Fixes
  1. Fixed issue where deleted lights were not properly synchronized.
  2. Fixed inconsistency between SketchUp layer visibility and rendered output.
  3. Fixed issue where environment/post-processing settings were not correctly loaded when switching scenes.
  4. Fixed jittering issue when adjusting HDRI brightness slider.
  5. Fixed error when switching from HDRI sky to custom sky.
  6. Fixed issue where sky brightness was not synchronized to D5 Renderer.
  7. Fixed abnormal camera behavior when switching left/right views in section scenes.
  8. Fixed issue where viewport zoom reset after adjusting FOV.
  9. Fixed crash caused by loading extremely large textures.
  10. Fixed abnormal behavior in AI history switching.
  11. Fixed hang and unexpected exit when exporting certain models in SketchUp.
Rhino 1.0.0 (Initial Release)
  1. Supports using D5 Lite inside Rhino with real-time rendering preview.
  2. Supports Rhino native materials and provides D5 material templates in the material panel.
  3. Supports reading Rhino native lights.
  4. Adapted viewport navigation for Rhino interaction patterns.
Revit 1.0.0 (Initial Release)
  1. Supports using D5 Lite inside Revit with real-time rendering preview.
  2. Supports real-time synchronization with D5 Render.
  3. Supports Revit 2027.
  4. Supports two sync modes: “Viewport Only Sync” and “Full Sync”.
  5. Supports Revit material mapping with adjustable parameters in the material panel.
  6. Supports Revit light synchronization and editing.
  7. Adapted viewport navigation for Revit interaction patterns.
  8. Improved overall export workflow, supporting custom export folders and separating main and linked models into independent files.
v1.4.0
2026/5/13
New
  1. Added support for Geo-Sky system
  2. Added support for environment sync, which syncs geographic environment or HDRI from SketchUp
  3. Added Billboard 2D assets to the Asset Library
  4. Added support for Always Face Camera on components
  5. Support syncing environment and post-processing from scene list to D5 Render
  6. Added keyboard shortcut for orbit/look-around operation (middle-click drag)
  7. Added support for Scatter “Render Only” mode
  8. Added undo/redo functionality
  9. Added right-click to reset material parameters
  10. Added support for AI material template recognition
Improvements
  1. Improved consistency of skp models across three workflows: LiveSync to D5 Render, Direct Read of skp, and Open skp in D5 Render
  2. Improved large texture file handling for better scene loading stability
Fixes
  1. Fixed grass template appearing too dark when grass blade textures are present
  2. Fixed misalignment of certain SketchUp models in the Lite viewport
  3. Fixed inconsistent scroll zoom speed compared to D5 Render
  4. Fixed models appearing black at certain viewing angles
  5. Fixed incorrect file save location when AI image save path contains a plus sign +
  6. Added keyboard shortcut support for switching between orthographic and perspective views
v1.3.1 Hotfix
2026/4/14
Improvements
  1. Improved large-scene handling performance, enhancing loading and runtime efficiency for SketchUp
  2. Optimized the SketchUp material recognition logic to prioritize: child front face > parent > child back face.
Fixes
  1. Fixed an issue in SketchUp where material texture positions could become inconsistent when materials were applied inside and outside a group.
v1.3.0
2026/03/30
New
  1. Added support for syncing SketchUp Section
  2. Added support for SketchUp orthographic views
  3. Improved emissive material ; cutout (alpha clip) is now supported
  4. Improved grass material
  5. Added support for SketchUp normal map convention settings (OpenGL / DirectX)
  6. Added support for Bump maps
  7. SketchUp opacity values are now linked to D5 Lite material parameters
  8. Base Color in D5 Lite are now synced to D5 Render
Fixes
  1. Fixed a mismatch between SketchUp normal map parameters and D5 Lite
  2. Fixed an issue where textures deleted in D5 Lite remained in SketchUp
  3. Fixed an issue where textures uploaded in SketchUp failed to appear in D5 Lite
  4. Fixed an issue where deleting the base color map caused the base color to fall back to the texture’s average color
  5. Fixed incorrect UV reads when no texture was assigned
  6. Fixed an issue where the selected material was not displayed when opening the Material panel for the first time
  7. Fixed an incorrect color mapping between solid color materials and emissive color settings
  8. Fixed an issue where alpha textures were mapped to the wrong material template when synced to D5 Render
  9. Fixed an issue where the water depth parameter caused models to clip through the water surface
  10. Fixed an occasional issue where AI image generation timed out
v1.2.0
2026/02/10
New
  1. Added sun parameters for HDRI, with support for custom sun direction
  2. The Material panel now supports adding PBR texture maps
  3. Improved glass material, including Metal Coating
  4. Added support for Disk Light
  5. Added shortcut key tips, which can be enabled or disabled in Settings.
  6. Added new human character assets
Fixed
  1. Fixed blurry font rendering on high-DPI displays
  2. Fixed an issue where light temperature could not correctly reset to default
  3. Fixed an issue where light color settings were not applied properly.
  4. Fixed crashes and file loading errors caused by file paths containing special characters
  5. Fixed an issue where the window could not be opened after switching files
  6. Fixed occasional installation failures
  7. Fixed occasional application crashes
v1.1.11
2026/01/22
Fixes
  1. Fixed a GPU memory issue after closing D5 Lite
  2. Fixed an occasional AI generation failure
  3. Fixed an issue where the viewport size could reset after being minimized and reopened
  4. Fixed an issue where LiveSync didn’t disconnect automatically after closing D5 Render
  5. Fixed an issue affecting SketchUp FBX export.
v1.1.10
2026/01/10
Improvements
  1. Improved glass material rendering quality
Fixes
  1. Fixed an issue where the viewport briefly reverted to the previous SketchUp file when switching between files
  2. Fixed ghosting artifacts on materials beneath water surfaces when moving the camera
  3. Fixed a crash when placing assets into SketchUp from Launcher
  4. Fixed a crash caused by importing CAD files
  5. Fixed a crash occurring when undoing grass material operations
v1.1.7
2025/12/30
Improvements
  1. When a light source has a color, the color option is now shown by default
Fixes
  1. Fixed occasional crashes or freezes when closing the D5 Lite window
  2. Fixed an issue where Strip Light could appear unlit at both ends at low brightness._
  3. Fixed an issue where D5 Lite and SketchUp processes remained running after closing Lite
  4. Fixed misalignment issues when zooming AI large images with the mouse wheel
  5. Fixed several UI display issues
v1.1.6
2025/12/26
New
  1. When switching from Render mode to AI mode, AI generation can now continue using the render screenshot
Fixes
  1. Fixed several crash issues
  2. Fixed an issue where the Lite window occasionally failed to stay on top of the SketchUp window
  3. Fixed an issue where mouse interactions in AI mode affected the rendering camera
  4. Fixed an issue where the effect panel was not fully displayed
v1.1.5
2025/12/24
Improvements
  1. Improved rendering quality for glass and water materials
  2. Improved rendering speed for water, grass materials, and multi-light scenes
  3. AI history timestamps are now displayed with second-level precision
  4. Reduced noise in real-time preview rendering
Fixes
  1. Fixed an issue where aspect ratios could not be saved in the scene list
  2. Fixed slow loading when selecting materials
  3. Fixed flickering when editing textures
  4. Fixed unintended camera movement when pressing WASD in the scene list
  5. Fixed an issue where editing one light affected other lights with the same color
  6. Fixed an issue where two-point perspective scenes reverted to perspective view
v1.1.4
2025/12/22
Improvements
  1. Improved water material rendering quality
Fixes
  1. Fixed an issue in SketchUp 2023 and later where Lite windows failed to launch and crashed on startup
  2. Fixed an issue where related processes did not exit correctly after closing SketchUp
  3. Fixed incomplete or abnormal lighting effect rendering
  4. Fixed an issue where no images were generated when FTP was selected as the render output path
  5. Fixed incorrect light visibility toggle states
  6. Fixed unstable remaining time estimation during rendering
v1.1.3
2025/12/19
Fixes
  1. Fixed an issue where the SuMore plugin failed to load when launching SketchUp after installing Lite
  2. Fixed a crash in SketchUp when importing CAD files
v1.1.2
2025/12/18
Fixes
  1. Fixed abnormal lighting rendering results
  2. Fixed inconsistencies between scaled light strips and their actual illumination range
  3. Fixed incorrect two-point perspective rendering
  4. Fixed abnormal water flow speed
  5. Fixed deviations in light color temperature rendering
  6. Fixed an issue where the AI preset panel could not scroll
  7. Fixed mismatched screenshots for multiple SketchUp files in AI mode
  8. Fixed a “Screenshot failed” error when launching Lite
  9. Fixed an “Unknown Error” during AI generation
  10. Fixed incorrect output paths when opening rendered images
  11. Fixed an issue where the settings window appeared unexpectedly on launch
  12. Fixed an issue where D5 Lite prompted login despite already being logged in via Launcher
v1.1.1
2025/12/16
Improvements
  2. Improved HDRI loading speed and clarity
  3. Improved overall rendering performance
Fixes
  1. Fixed login conflicts between D5 Lite and D5 Launcher
  2. Fixed post-processing color issues
  3. Fixed excessively slow mouse rotation spee
v1.1.0
2025/12/12
Improvements
  1. D5 Engine upgrade with significant improvements in performance and visual quality
  2. Improved visual quality of real-time rendering previews
  3. Improved model loading speed
  4. Enhanced final render image quality
  5. Optimized parts of the UI and interaction logic
  6. Added support for SketchUp 2026
Fixes
  1. Fixed UI performance lag issues
  2. Fixed an issue where resized windows could not be restored
  3. Fixed installation conflicts with the D5 LiveSync plugin
v1.0.4
2025/10/28
Improvements
  1. Optimized window UI for high-resolution displays
  2. Exposure parameters can now be switched to an input field for precise value control
  3. Parameters can now be reset to default via right-click
  4. AI style presets, inspiration text, and related panels are now freely resizable
  5. AI generation results can now be zoomed in and out using the mouse wheel
  6. File paths for materials, HDRIs, and render outputs are now saved independently
  7. Improved window animation
  8. Refined parts of the UI styles
Fixes
  1. Fixed blurry AI preset thumbnails
  2. Fixed an issue where replacing reference images had no response
  3. Fixed occasional issues with window always-on-top behavior
  4. Fixed an issue where brush-painted vegetation disappeared after syncing to Render
v1.0.3
2025/10/14
AI Mode
  1. New reference image upload: intelligently extracts color palettes, material qualities, and lighting features from your reference images.
  2. New style presets: expanded to over 150+ categories, including architectural types and new presets for landscapes, parks, plazas, water features, hotels, commercial spaces, exhibition halls, theaters, stages, and weddings.
  3. Structure Matching Weight: now offers three modes: Default, Creative, and Precise, replacing the previous slider control. Precise Mode replaces the former “Lock Material” function.
  4. Creative Mode optimization: delivers more diverse, imaginative, and inspiring results.
  5. Precise Mode optimization: produces results with finer detail and closer alignment to your design intent.
  6. Aerial view enhancement: improved recognition of roads.
  7. Updated style preset thumbnails and descriptions: clearer, more informative visuals.
Render Mode
  1. Livesync plugin integration: unified access point for all sync functions.
  2. View link toggle: control D5 Lite and SketchUp cameras independently.
  3. One-time model sync: lower performance overhead, ideal for partial updates.
  4. Improved camera rotation: smoother continuous rotation with refined hidden cursor behavior.
  5. Improved mouse rotation sensitivity.
Fixes
  1. Fixed rendering errors caused by parameter adjustments during rendering.
  2. Fixed crashes when switching between SketchUp files.
  3. Fixed incorrect window scaling when reopening the program.
  4. Fixed missing tooltip for structure matching weight on hover.
  5. Fixed failure to generate results when input text contained special characters in AI Mode.
v1.0.2
2025/09/18
Features
  1. Support Enscape parameters, including materials, lighting, and environment
  2. Support adjusting the FOV in the Lite render viewport (shortcut: Alt + mouse wheel).
  3. Support adjusting camera movement speed in the Lite render viewport (shortcut: right mouse button + mouse wheel).
  4. Support camera navigation in two-point perspective in the Lite render viewport.
Fixed
  1. Fixed flickering in the render viewport when adjusting material parameters.
  2. Fixed stuttering in some cases when adjusting materials.
  3. Fixed an issue where deleting a scene could delete the wrong scene.
  4. Fixed an issue where scenes created under two-point perspective were reverted to non-two-point perspective.
  5. Fixed an issue where holding Shift while moving with the right mouse button incorrectly switched to panning.
  6. Fixed excessive initialization time when loading a large number of assets.
  7. Fixed an issue where the menu did not appear when “Install for all users” was selected.
v1.0.1
2025/08/21
Features
  1. Scene List Support
    a. Sync scenes from SketchUp
    b. Create scenes in Lite, saving environment, post-production, and other settings to each scene
  2. Improved rendering for glass, emissive, and grass materials
  3. Optimized real-time rendering performance
  4. Improved material editor performance
  5. Better consistency between real-time highlights/reflections and final rendering
  6. Enhanced scene loading progress display
  7. Smoother real-time rendering UI
Fixes
  1. Fixed issue where re-uploaded HDRI files failed to load
  2. Fixed black screen flicker when loading HDRI files
  3. Fixed inconsistency between exposure compensation in Lite and D5 Render
  4. Fixed light source brightness mismatch with Render
  5. Fixed emissive material changes when moving the camera
  6. Fixed orientation mismatch between proxy assets and detailed models
  7. Fixed issue where proxy assets did not correctly show undetailed models during sync
  8. Fixed material issues under low exposure values
  9. Fixed issue where texture maps sometimes failed to display in the material editor
  10. Fixed occasional issue where Lite camera didn’t follow SketchUp view
  11. Fixed occasional issue where scene initialization froze
  12. Fixed various UI errors
  13. Fixed issue where opening multiple SKP files caused Lite to start with the wrong file
  14. Fixed issue where SketchUp window disappeared when setting specific scenes to always-on-top
  15. Fixed other occasional crashes and instability issues
v1.0.0
Feature & Optimizations
  1. Added support for D5 Engine
  2. Improved real-time rendering frame rate
  3. Added exposure compensation
  4. New Interior Commercial category (includes retail, office, hotel, etc.)
  5. Enhanced Architecture & Landscape categories with better aerial view quality
  6. Improved accuracy of structure match weight
Fixes
  1. Fixed some SKP file loading failures
  2. Fixed viewport moving issue caused by mouse wheel on post-production page
  3. Fixed render window changes during rendering
  4. Fixed rendering errors caused by aspect ratio changes
  5. Fixed crash caused by HDRI uploads
  6. Fixed glass transparency and noise issues
  7. Fixed tone adjustment not working
  8. Fixed metal roughness not working
  9. Fixed issue with images and models imported from SketchUp menu not showing
  10. Fixed issue where deleted textures still showed color
  11. Fixed image flickering after AI image generation
  12. Fixed some cases where proxy assets couldn’t be placed
  13. Fixed inconsistent asset library loading order
  14. Fixed UI black border issue
A post was split to a new topic: Sketchup 2023 won’t lunch after installed Lite
A post was split to a new topic: Lite insufficient permission
Hi, I’ve been using D5 Lite since 1.1. I think the recent update is not linked to SketchUp hiding objects. I think around version 1.2, hiding objects in each scene is synced. But from 1.3( I guess), I have to unhide all and hide the object again for a different scene.
@wwtp43406 Yes, this is a bug and will be fixed in the next release, expected at the end of June.
