Interface and controls requests
D5 is really clunky to operate. Here are my suggestions to smooth out the experience:
1: Deselecting. Right now, to deselect something, you need to click again on the object, or click the sky. It is really not intuitive. Instead, just keep it a shortcut.
2: Move speed indicator: When in fly mode, the speed adjust is not working very well. You go SUPER fast, then scroll a bit, and go SUPER slow. You never know what your speed is. Make a small indicator on the top right corner showing you the speed. maybe cap it to a high value, but not ridiculously fast. And make the speed change logarithmic or something like that, because I need more precision at small speeds than at higher speeds.
3: double click to move to location. Enscape has this feature. Double click somewhere, and you will fly to the location. Greatly speeds up the navigation around the model.
4: More seamless camera properties. I am still confused why there are size controls for the camera, and the scene like export sizes/resolution. Which one takes priority? Why are there two. And what happens when I render an animation? My camera settings dont work anyumore? Really confusing. I suggest having export/resolution only on one place.
5: click drag to select multiple. Moving stuff inside d5 is tedious. When I want to move multiple objects like lights, I would like to be able to select multiple, instead to having to click each individual light.
Thank you!
