Not bad to have instance material function in D5 Render!
Example:
Let’s say 5 cubes of different colors come from the sketchup, and in D5 we want to paint all these cubes with one material tree, and if we start editing this material, then we will have to copy it over to all other cubes, but if the material is instanced, then no.
Hi morozovsimon, thanks for your suggestion! This function requires a change to the D5 Converter. We may add it in the future. For now, the material picker (shortcut: I) can make the copy process easier. Hope this can help you!
hey guys, I know this feature is pretty fun, but did you know you can “Make Objects Instance” in D5 render? it works for similar objects. for example you 3 boxes and they are not instances. what you can do is to place one in local library, then select all 3 and “Replace them from Asset Library” at the same time. this will import them as instance.
– not as good as instance material but certainly useful
