I mainly use Rhino for rendering with D5 Render.
For example, after rendering Design 1 in a building scene using a Render View, I sometimes turn off sync in Rhino, switch to Design 2 by enabling different layers, and then re-enable sync to add Design 2 to another Render View.
However, when I do this, the previous Render View with Design 1 no longer reflects correctly—it gets overwritten or replaced by Design 2.
I’m wondering if this issue could be addressed in a future update. It would be really helpful if Render Views could retain their original layer states or content, even after syncing new geometry from Rhino.
Currently, it’s quite inconvenient to create separate files or duplicate Render Views just to render different design options from a single Rhino file using layer visibility.
