you see when you import an asset or press Ctrl D and copy an existing object and decide to use C or R to scale or rotate the imported or copied object, this action will also cause the next object you choose from asset library to be exactly at the size or the angle of last object.
now I know this is definitely as intended, any millions of users want it this way and never want change, but not even once in my entire D5 life I needed it that way. I actually have to either press “reset” after importing or go through once copying an object which I already did reset so it resets the action.
also, this is why I avoid using C or R as much as possible. so maybe just pressing shift or something could “reset” it? or making my desire the default option (if others agreed with me) and instead a shortcut for “use last input”?
Sincerly
MJ
