Hi, in 3D Studio Max I have three objects, each for a single layer. I’m trying everything, but in D5 I always see only one layer. That is, I don’t have individual objects, but a group… where am I going wrong? Thanks.
I’ve done every type of one-layer or two-layer export from 3D Studio Max.
From export. I was following a video where they used Rhino and I’m not mistaken and everything worked fine with the same Rhino layers even on D5. Nothing, I understood that 3DS Max does not support this thing. I imported the scene several times so as to have 3 or 4 blocks/layers.
I ran into this too! Currently, D5 tends to group everything by material rather than by your original layers. The best workaround I’ve found is to make sure every ‘layer’ has a unique material name in your modeling software before you sync. Once it’s in D5, you can then select by material to hide or edit things easily.
