I currently use D5 version 1.7.1.0274.
Does this D5 version already support SKP 2021 file ?
I can’t import import V2021 version and can’t sync model.
Thanks.
Thanks.
Hi there,
Please check out D5 Converter for Sketchup, which is compatible with 2021
Hi Jessie
Thank you very for your reply. I also got explanation from D5 support.
We can open SKP2021 file in D5 by using D5 converter inside Sketch Up but cannot
cannot use import menu in D5 to direct import SKP2021 file. (It work with SKP 2020 file)
Hope new update version and fix this soon.
Probably will be available in the next version.
Thank you very much
