It would be great if we can have image sequence texture setting in D5. Hope to hear about it soon.
we halve this already?
or do you think about something else?
the multimedia texture messes up frame sequence and we do not have control over frames for that. If we look at max or blender there are image sequence material nodes which gives control for proper sequence of frames for the textures.
Better to explain futher what you need.
The small discription does than not describe what you want i think.
I need multimedia texture with controls. To control the frames of a video like we do for animated objects. For animated objects we have offset to control every frame. I want something like that for multimedia texture.
this option is much needed. all the other programs have image sequence with a lot of control over them. the multimedia is not accurate, and it even has different purpose. image sequence is defined based on frames, where multimedia is a fun way to show animation
