[PT Tips & Suggestions] I’m sending some Juice for you D5 GEEKS
I’m sending some Juice for you D5 GEEKS: check here for images:
https://drive.google.com/drive/folders/1iLYuoHcz3N0oZlXCDJ8oIoyddYTneqrR?usp=sharing
Here are my render times using an RTX 4060 Ti 16GB:
  • Render 1: Ray Tracing – 3:55
  • Render 2: Path Tracing (Lowest: 1:1:64) – 4:47
  • Render 3: Path Tracing (Mid GI, Low Reflection: 2:1:64) – 7:11
  • Render 4: Path Tracing (High GI, Low Reflection: 3:1:64) – 7:59
  • Render 5: Path Tracing (Default: Low GI, Mid Reflection: 1:2:64) – 5:56
  • Render 6: Path Tracing (Low GI, High Reflection: 1:3:64) – 6:40
  • Render 7: Path Tracing (Mid GI, Mid Reflection: 2:2:64) – 9:18
  • Render 8: Path Tracing (High GI, High Reflection: 3:3:64) – 12:04
  • Render 9: Path Tracing (Highest: 3:3:256) – 45:56
MY Recommendations
  • Path Tracing is a must – A 22% render time increase is nothing for the added realism.
  • GI Precision? leave it at 1– Unless you have specific cases where it does makes a difference.
  • Reflection Depth?1 vs. 2 is a real choice. Do you want higher contrast or smoother reflections? I’d go with 1 unless critical details are lost.
  • SSP? Keep it at 64 – No need for more unless you notice artifacts in very dark areas. Even comparing high SPP settings, I didn’t see much difference.
Hi @DynamicRenderLabs
Truly Helpful, thank you for this information!
