If you import/use the asset library in D5 after exporting the 3D you created in Rhino, you wont be able to convert back the assets you used back into Rhino. This would be very usefull for using the “Make2D” command inside of Rhino for 2D drawings of your design/space.
Is there any “work around” for this? Has anyone found a solution?
Maybe making the asset library inside of Rhino like Chaos Cosmos does for Vray?
