I need to make some ground differences and I notice once I have 2 different planes once with grass and then the other one with ground material I get this effect, is there any way to fade this to get it more realistic?
Hi @elocobes , the current technical solution for Grass Material Template has this problem for model edges, where the borders will not be easily aligned.
Single grass of the Grass Material Template is provided in the Assets Library and can be used to supplement the boundaries. For close up, it is recommended to use the same type of grass in the model library to draw with the Brush function. We will consider optimizing this issue in subsequent release.
Thanks
Lia
it is interesting this option, even so it is difficult to get the scale and density right and it is noticeable when you do it with the brush.
